NShan12
5 years agoTiming analysis error on Asynchronous control signals
In my design, there is an asynchronous bus between FPGA and Microcontroller (Master). FPGA uses the edges on the signals WRN (Write active) and ALE (Address Enable) to classify if the signa...
SyafieqS
4 years agoHi Naveen,
"In any case, how can I solve the unconstrained clock warning by the timing analyzer"
- Assuming I understand your question, have you able to constrain all the clocks in sdc? This should reflect in Timing Analyzer
NShan12
4 years agoHi,
Yes, all the clocks (on IO ports, generated clocks, virtual clocks etc.) are constrained in the SDC file. Since WRN and ALE are not clocks only false path constraints exist on them.
