15 years ago
Timer Interrupts with Nios II
Hello guys,
I am using the DE0 board and I want to implement a timer interrupt to trigger a PWM signal every 1 ms. The DE0 board has a cyclone III and I use Quartus II (ver 9.1sp2) & NIOS II (ver 9.1). I have setup the nios system as given in NIOS II hardware tutorial.
I tried to run a timer interrupt C code from the interrupt example as given in the University Program. The program compiles. However, when I try to run it I get the following error message.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x00011088: verified
Initializing CPU cache (if present)
OK
Downloading 00000020 ( 0%)
Downloading 00008000 ( 0%)
Downloaded 8KB in 0.1s
Verifying 00000020 ( 0%)
Verify failed between address 0x20 and 0x43
Leaving target processor paused
Why do I get this error message? How can I address this problem. Thanks in advance.
    yes he´s right. The problem seems to come with wrong SDRAM settings!
    You should check the address on the Nios2 system you build. I guess, between 0x20 and 0x43 address, you may place an SDRAM.
    If that, you can assign a pin for SDRAM_CLK.You can get SDRAM_CLK from PLL.
