15 years agoTimer Interrupts with Nios II
Hello guys, I am using the DE0 board and I want to implement a timer interrupt to trigger a PWM signal every 1 ms. The DE0 board has a cyclone III and I use Quartus II (ver 9.1sp2) & NIOS II (...
15 years agoVerify failed between address 0x20 and 0x43
======================================= You should check the address on the Nios2 system you build. I guess, between 0x20 and 0x43 address, you may place an SDRAM. If that, you can assign a pin for SDRAM_CLK.You can get SDRAM_CLK from PLL.
