8 years agoTimequest constraints for a dynamically phase-shifted PLL
I've been trying to properly constrain a design that uses dynamic phase shifting of an instance of an altera_pll core that I created. I.e. to enable phase-shifting I checked the "enable access to dy...
8 years agoI read your "generating appropriate clock enables to sample the signal with enough setup and hold time for each clock transfer at each phase setting" to mean do I have the timing constraints properly in place for all phases by having only two ‘set_multicycle_paths’ in my Timequest constraints file (because it seems unlikely at first glance that those two would cover all eight phases, but they appear to me to do).
So, do you mean am I using clock enables AKA gated clocks? I.e. such as those described in the “Clock Enable Multicycle” section of ‘mnl_timequest_cookbook.pdf’, page 25 {document revision 2017.11.21}]? If that’s what you meant, I am not using any gated clocks. Thanks for your continued interest.
