lambert_yu
Contributor
2 years agoThere's minimum pulse violation for IOPLL under source synchronous operation mode
Hi, I am facing one issue when I design the source synchronous lvds project. case: quartus II : 18.0.0 standard speed : 1.6Gbps; PLL : use external PLL ref clk for PLL: 800Mhz op...
- 1 year ago
May I know which LVDS functional mode are you using?
You will need to use the PLL compensation mode provided in the User Guide, for the corresponding LVDS functional mode.
Richard Tan
RichardT_altera
1 year agoHi,
Do you able to share your project?
Richard Tan
- lambert_yu1 year ago
Contributor
Hi, Richard
I coudn't export my design from internal network, and I only provide related configuration and related timing violation report, I don't know if it's okay for you to find the same issue. Related information as below figures:
And if I change the Compensation mode from synchrous -> direct, there's no this minimum pulse issue.
Lambert
