8 years ago
The problem for using DPA PLL
for my project, I need receive 5 channels 500M LVDS sigal and with 50M sync following clock,
I add a PLL for every following clock and generate 50M Phase342, 500M Phase180, 50M Phase288 Duty10 three clocks and connected to serdes.
My FPGA is 5CGXFC7D6F27C7 own 7 PLLs.
Besides these 5 PLL, i also use one for system clock which refclk input is osc. Totally 6 pll, and Place and Route can pass successfully.
In order to improve sampling accuracy, i open the dynamic phase adjust (DPA) function for those 5 PLLs.
When place and route, the error is shown below:
Error (175020): Illegal constraint of fractional PLL to the region (x-coordinate, y- coordinate) to (x-coordinate, y-coordinate): no valid locations in regionError (175020): Illegal constraint of fractional PLL to the region (x-coordinate, y- coordinate) to (x-coordinate, y-coordinate): no valid locations in region
is this means if i open DPA function of PLL, the FPGA cannot use 7 PLLs anymore?
How can I solve this problem?
Thanks in advance.
Qi
    Insert an ALTCLKCTRL megafunction in the clock path between the dedicated clock input pin and the Altera_PLL. Note, using a global primitive or global signal assignment for the clock signal is not sufficient, the ALTCLKCTRL megafunction must be instantiated in your design.
    This is not necessary when the clock input pin has dedicated access to the Altera_PLL.
