17 years agoThe lowest frequency!
everyone for me ask that the lowest frequency when use FIR megacore!
Change your sample rate to something ~10 times your cutoff and you should get decent results. You can change your clock rate by using a clock enable and the multicycle properties in the megawizard for the FIR.
thanks alot!
--- Quote Start --- but i try whith sample rate 10MHz and filter type is bandpass have cutoff are 200Hz and 300Hz --- Quote End --- That's not impossible in theory, but practically, cause you would require several thousand FIR taps in this case. Just consider, that the filter must have at least a length equivalent to several periods of the characteristic filter frequencies. You can either build IIR filters, although they need a rather large coeffecient length and a lot of extra fractional bits, but they are basically feasible for such extreme frequency ratios. Or use a decimation before the filter. - Altera_Forum
Your figures don't sound right to me. You are asking for very unusual cutoff points. You better check your requirements first.
Thanks kaz! but i try whith sample rate 10MHz and filter type is bandpass have cutoff are 200Hz and 300Hz, then I see out put equa 0. can you help me?
You should use the same speed as the sampling rate(Fs) of your input signal.
Your cutoff point is then related to that Fs. For example if a lowpass filter cutoff is 0.25Fs and your signal rate is 12MHz then the cutoff will be 3MHz meaning all frequencies from 0 to 3MHz are passed. your frequency may be labelled in terms of Fs ratio or in radians(0 ~ pi) where pi means .5Fs For more advanced designers, you can pass your input signal to a higher or lower data rate(interpolation/decimation)
