17 years agoThe lowest frequency!
everyone for me ask that the lowest frequency when use FIR megacore!
17 years agoYou should use the same speed as the sampling rate(Fs) of your input signal.
Your cutoff point is then related to that Fs. For example if a lowpass filter cutoff is 0.25Fs and your signal rate is 12MHz then the cutoff will be 3MHz meaning all frequencies from 0 to 3MHz are passed. your frequency may be labelled in terms of Fs ratio or in radians(0 ~ pi) where pi means .5Fs For more advanced designers, you can pass your input signal to a higher or lower data rate(interpolation/decimation)
