The issue of FPGA not detecting the JTAG chain
- 1 year ago
Hi xingyunzhidi,
Thanks for test it out.
As the configuration is ok when set to JTAG only, but failed when set to AVST, it is likely that the AVST configuration scheme could have something wrong. A few possible reasons below, you may check one by one.
1- The bitstream in the FLASH is corrupted. If so, you need to erase the FLASH. (If you can not figure out how to erase the FLASH, Let me know which devkit you are using, then I can check the schematic. ) Did this issue happen after you tried to program a POF file to FLASH? If so, then there could be something wrong with this POF.
2- The AVST master is not working properly. Normally there's another FPGA/CPLD works as the AVST master to program the target FPGA. You can check if the board has any LED to indicate this master CPLD is working. Or have you changed the image of this master FPGA/CPLD somehow?
3- The FPGA AVST interface has something wrong.
Xiaoyan
I checked the SW section in the FPGA manual. When I set the SW as per the default configuration, I encounter the previously mentioned error ("unable to scan the JTAG chain") and BTS is unable to detect it. However, when I set SW2.1 to OFF (i.e., JTAG instead of AVST×8), it is recognized correctly, and BTS can detect it and program the FPGA with the .sof file. The FPGA manual mentions two configuration modes, but when generating the .pof, it seems like only the AVST mode can be selected. How can I generate a .pof for the JTAG programming mode (with SW2.1 set to OFF)?
pic
