OrF's avatar
OrF
3 years ago
The Fitter failed to find a legal placement for IOPLL with DIB of Stratix 10.
I got the next Error from the Fitter while trying to synthesis with DIB
The Fitter Failed to find legal placement for my IOPLL
is there a way to find out which PLL is preferred by the DIB , or vise versa any methodical way to find out which DIB subsystem / channel or bank I choose - since I know what are my free PLL.
(BTW I have many free pll, but somehow they does not good enough for usage by the fitter due to DIB location )
this is the Error I get:
Error (14996): The Fitter failed to find a legal placement for all periphery components
Error (14986): After placing as many components as possible, the following errors remain:
Error (175001): The Fitter cannot place 1 IOPLL.
Info (14596): Information about the failing component(s):
Info (175028): The IOPLL name(s): f1|cnvr_dib_rx_pll_inst|iopll_0|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll
Error (16234): No legal location could be found out of 24 considered location(s). Reasons why each location could not be used are summarized below:
Error (175006): There is no routing connectivity between source DIB_DIB_PHY and the IOPLL
Info (175026): Source: DIB_DIB_PHY f1|cnvr_dib_wrapper_ins|dib_rx_2_22|dib_0|dib_ch|arch_inst|phy_inst|xphy_inst
Info (175013): The DIB_DIB_PHY is constrained to the region (442, 290) to (442, 290) due to related logic
Info (175015): The I/O pad DIE1_dib_pad_2_22_0[0] is constrained to the location PIN_DIB0_CH22_X1Y2 due to: User Location Constraints (PIN_DIB0_CH22_X1Y2)
Info (14709): The constrained I/O pad contains this DIB_DIB_PHY
Info (175015): The I/O pad DIE1_dib_pad_2_22_3[22] is constrained to the location PIN_DIB94_CH22_X1Y2 due to: User Location Constraints (PIN_DIB94_CH22_X1Y2)
Info (14709): The constrained I/O pad drives a DIB_DIB_IO_WRP, which drives this DIB_DIB_PHY
Info (175021): The DIB_DIB_PHY was placed in location DIBDIBPHY_X442_Y290_N1
Error (175022): The IOPLL could not be placed in any location to satisfy its connectivity requirements
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Thank you for reaching out Intel FPGA Community.
    This error basically caused by the Fitter cannot place the specified logic element in the design.
    Could you share the test case design with us? so that I can try to replicate and isolate the issue.
    You can choose to share here or privately.
    Just let me know which you prefer.
    Aqid
