16 years agoThe difference between the RTL level simulation and the Gate lavel simution
HI! Everyone! I am using Quartus ii web 9.1 . Now There is a problem between the RTL level simulation and Gate lavel simution. I need help! this is the code: LIBRARY IEEE; USE IEEE...
16 years agorbugalho,
Thanks for your reply. I tried before according to your method. It's OK to spcify initial values to the variables temp and count , But when I use an explicite reset(your second way) , there is still a question. This is the code After the modification: LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY SKFP IS PORT(CLK : IN STD_LOGIC; RST : IN STD_LOGIC; -- '0' IS VALID DATA: IN STD_LOGIC_VECTOR(7 DOWNTO 0); FP : OUT STD_LOGIC ); END ENTITY SKFP; ARCHITECTURE ART OF SKFP IS SIGNAL FULL: STD_LOGIC; BEGIN PROCESS(CLK,RST) VARIABLE COUNT:STD_LOGIC_VECTOR(7 DOWNTO 0); BEGIN IF RST='0' THEN FULL<='0'; ELSE IF CLK'EVENT AND CLK='1' THEN IF COUNT="11111111" THEN COUNT:=DATA; FULL<='1'; ELSE COUNT:=COUNT+1; FULL<='0'; END IF; END IF; END IF; END PROCESS; PROCESS(FULL,RST) VARIABLE TEMP: STD_LOGIC; BEGIN IF RST='0' THEN FP<='0'; ELSE IF FULL'EVENT AND FULL='1' THEN TEMP:=NOT TEMP; IF TEMP='1' THEN FP<='1'; ELSIF TEMP='0' THEN FP<='0'; END IF; END IF; END IF; END PROCESS; END ARCHITECTURE ART; and the testbench is: -- Copyright (C) 1991-2009 Altera Corporation -- Your use of Altera Corporation's design tools, logic functions -- and other software and tools, and its AMPP partner logic -- functions, and any output files from any of the foregoing -- (including device programming or simulation files), and any -- associated documentation or information are expressly subject -- to the terms and conditions of the Altera Program License -- Subscription Agreement, Altera MegaCore Function License -- Agreement, or other applicable license agreement, including, -- without limitation, that your use is for the sole purpose of -- programming logic devices manufactured by Altera and sold by -- Altera or its authorized distributors. Please refer to the -- applicable agreement for further details. -- *************************************************************************** -- This file contains a Vhdl test bench template that is freely editable to -- suit user's needs .Comments are provided in each section to help the user -- fill out necessary details. -- *************************************************************************** -- Generated on "08/23/2010 12:22:05" -- Vhdl Test Bench template for design : SKFP -- -- Simulation tool : ModelSim-Altera (VHDL) -- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY SKFP_vhd_tst IS END SKFP_vhd_tst; ARCHITECTURE SKFP_arch OF SKFP_vhd_tst IS -- constants -- signals CONSTANT NEWCLK:TIME:=20 NS; SIGNAL CLK : STD_LOGIC; SIGNAL DATA : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL FP : STD_LOGIC; SIGNAL RST : STD_LOGIC; COMPONENT SKFP PORT ( CLK : IN STD_LOGIC; DATA : IN STD_LOGIC_VECTOR(7 DOWNTO 0); FP : OUT STD_LOGIC; RST : IN STD_LOGIC ); END COMPONENT; BEGIN i1 : SKFP PORT MAP ( -- list connections between master ports and signals CLK => CLK, DATA => DATA, FP => FP, RST => RST ); DATA<="11111100"; RST_TEST:PROCESS BEGIN RST<='0'; WAIT FOR NEWCLK*5; RST<='1'; WAIT FOR NEWCLK*20; RST<='0'; WAIT FOR NEWCLK*3; RST<='1'; wait for newclk*500; END PROCESS RST_TEST; init : PROCESS -- variable declarations BEGIN CLK <= '0'; WAIT FOR NEWCLK/2; CLK <= '1'; WAIT FOR NEWCLK/2; END PROCESS init; END SKFP_arch; This is the printscreen: http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_mo3.bmp
