CAlex's avatar
CAlex
3 years ago
The cyclone v soc GIC interrupt priority issues
I'm doing a baremetal multi task issue in cyclone V soc, I've learned that the cycloneVsoc used the PL390 GIC.
I now have 3 FPGA IRQs:
no.74 a timer counter interrupt every 50us (base tick).
no.75 a counter interrupt every 1ms based on the base tick.(fast task)
no.76 a counter interrupt every 5ms based on the base tick.(slow task)
What I want to achieve is that
1.base tick can not be interrupted and can interrupt other two IRQs.
2.The fast task can be interrupted by the base tick but cant be interrupted by the slow one.
3.The slow task can be interrupted by the others.
I've studied the GIC and found out it only choose the highest IRQ and send it to the CPU,
so I want to know whether it allow the high priority FPGA IRQ interrupt the low one.
Also, while makig the IRQ through the Avalon mm bridge, I was informed that irq signal must be set until the GIC told you that you are informed.
However, I want to use the edge trigger instead of level one.
Do you have any ideas to deal with that?
Reguards
Alex
  • Hi,
    Please check this below API function, you can also directly set the LEVEL or EDGE triggered.
    ALT_STATUS_CODE alt_int_dist_trigger_set(ALT_INT_INTERRUPT_t int_id,
    ALT_INT_TRIGGER_t trigger_type)
    // See GIC 1.0, section 4.3.12.
    if ((uint32_t)int_id >= ALT_INT_PROVISION_INT_COUNT)
    return ALT_E_BAD_ARG;
    else if ((alt_int_flag[int_id] & INT_FLAG_IMPLEMENTED) == 0)
    else if (int_id < 16)
    if ( (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
    || (trigger_type == ALT_INT_TRIGGER_SOFTWARE))
    return ALT_E_SUCCESS;
    else
    else
    uint32_t regoffset = int_id >> 4;
    uint32_t regbitshift = ((int_id & 0x0F) * 2) + 1;
    if (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
    if (int_id <= 32) { trigger_type = ALT_INT_TRIGGER_EDGE; } // PPI
    else if (int_id <= 40) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU0_PARITYFAIL
    else if (int_id <= 47) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU0_DEFLAGS
    else if (int_id <= 56) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU1_PARITYFAIL
    else if (int_id <= 63) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU1_DEFLAGS
    else if (int_id <= 66) { trigger_type = ALT_INT_TRIGGER_EDGE; } // SCU
    else if (int_id <= 69) { trigger_type = ALT_INT_TRIGGER_EDGE; } // L2_ECC
    else if (int_id <= 70) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // L2 (other)
    else if (int_id <= 71) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // DDR
    else if (int_id <= 135) { /* do nothing */ } // FPGA, !!!
    else { trigger_type = ALT_INT_TRIGGER_LEVEL; } // everything else
    switch (trigger_type)
    case ALT_INT_TRIGGER_LEVEL:
    alt_clrbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
    break;
    case ALT_INT_TRIGGER_EDGE:
    alt_setbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
    break;
    default:
    "Did you suggest I test the time form the isr signal send to GIC to the interrupt callback function called". Yes in C code only can write piece of code for timer before ISR start and end.
    Tiwari
  • Jeet14's avatar
    Jeet14
    I believe your enquiry has been answered. With that, I now transition this thread to community support.
    Thank you.
    Tiwari
    • CAlex's avatar
      CAlex
      Sure, thank you for your help
      please do whatever you need to do with this thread.
  • Jeet14's avatar
    Jeet14
    else
    else
    break;
    break;
    default:
    Tiwari
    • CAlex's avatar
      CAlex
      break;
      break;
      default:
      FPGA will do nothing, which cause the return ALT_E_BAD_ARG, so FPGA cant use AUTODETECT.
  • Jeet14's avatar
    Jeet14
    I think you can calculate time by using the timer before starting the ISR and stopping at the end of ISR.
    Also, in below API,
    "alt_int_dist_trigger_set(ALT_INT_INTERRUPT_GPIO2, trigger_type);"
    trigger_type:
    1. ALT_INT_TRIGGER_AUTODETECT
    2. ALT_INT_TRIGGER_EDGE
    3. ALT_INT_TRIGGER_LEVEL
    Tiwari
    • CAlex's avatar
      CAlex
      For SOC_CV_AV, using AUTODETECT will return -1 for FPGA interrupt int register.
      Please check the <alt_interrupts.c> line 838 to 851
      "I think you can calculate time by using the timer before starting the ISR and stopping at the end of ISR."
      Please correct me if Im wrong:
      Did you suggest I test the time form the isr signal send to GIC to the interrupt callback function called?
  • Jeet14's avatar
    Jeet14
    FPGA to HPS interrupts can be used as edge or level trigger and their GIC interrupt number is from 72 to 135.
    You need to keep the signal set until the ISR is not executed, at the end of ISR execution you can reset the signal.
    You can use the API to set the interrupt trigger type from the #include "alt_interrupt.c".
    alt_int_dist_trigger_set(ALT_INT_INTERRUPT_GPIO2, ALT_INT_TRIGGER_AUTODETECT);
    Tiwari
    • CAlex's avatar
      CAlex
      Hi
      "You need to keep the signal set until the ISR is not executed, at the end of ISR execution you can reset the signal."
      I want to avoid that if possible. The tasks are very time related, so I want to use edge trigger and let the signal auto reset in case other ISR block the tunnel. Do you know how long the ISR needs to be set ? Or how to calculate the presice time pluse needed?
      "alt_int_dist_trigger_set(ALT_INT_INTERRUPT_GPIO2, ALT_INT_TRIGGER_AUTODETECT);"
      For this case, the FPGA ISR cant be set to AUTODETECT. You must choose EDGE or LEVEL trigger.
      I hope this can help others.
      Thank you
  • Jeet14's avatar
    Jeet14
    FPGA to HPS interrupts are from 72 to 135. These interrupt priority & trigger type you can set using the API from the HWLIB library.
    Include the header file in your main file and check for the interrupt priority setting function and the trigger type i.e. edge or level.
    #include "alt_interrupt.h"
    Tiwari
    • CAlex's avatar
      CAlex
      What signal form should be like for edge trigger for interrupt sender?
      Acording to avalon MM bridge use guide interrupt send, the irq signal should always be set until HPS GIC respond.
      so how long do I need to keep that signal to be set?
      I can't use level trigger for this signal is very time related signal, as a result I cant mainuly reset the signal.
  • Jeet14's avatar
    Jeet14
    I will be working on this case.
    Please do allow some time to check and will update you ASAP.
    Tiwari
    • CAlex's avatar
      CAlex
      Thank you for your help,
      Looking forward to your reply.
