CAlex's avatar
CAlex
3 years ago
The cyclone v soc GIC interrupt priority issues
Hi, I'm doing a baremetal multi task issue in cyclone V soc, I've learned that the cycloneVsoc used the PL390 GIC. I now have 3 FPGA IRQs: no.74 a timer counter interrupt every 50us (base tick). ...
  • Jeet14's avatar
    3 years ago
    Please check this below API function, you can also directly set the LEVEL or EDGE triggered.
    ALT_STATUS_CODE alt_int_dist_trigger_set(ALT_INT_INTERRUPT_t int_id,
    ALT_INT_TRIGGER_t trigger_type)
    // See GIC 1.0, section 4.3.12.
    if ((uint32_t)int_id >= ALT_INT_PROVISION_INT_COUNT)
    return ALT_E_BAD_ARG;
    else if ((alt_int_flag[int_id] & INT_FLAG_IMPLEMENTED) == 0)
    else if (int_id < 16)
    if ( (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
    || (trigger_type == ALT_INT_TRIGGER_SOFTWARE))
    return ALT_E_SUCCESS;
    else
    else
    uint32_t regoffset = int_id >> 4;
    uint32_t regbitshift = ((int_id & 0x0F) * 2) + 1;
    if (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
    if (int_id <= 32) { trigger_type = ALT_INT_TRIGGER_EDGE; } // PPI
    else if (int_id <= 40) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU0_PARITYFAIL
    else if (int_id <= 47) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU0_DEFLAGS
    else if (int_id <= 56) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU1_PARITYFAIL
    else if (int_id <= 63) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU1_DEFLAGS
    else if (int_id <= 66) { trigger_type = ALT_INT_TRIGGER_EDGE; } // SCU
    else if (int_id <= 69) { trigger_type = ALT_INT_TRIGGER_EDGE; } // L2_ECC
    else if (int_id <= 70) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // L2 (other)
    else if (int_id <= 71) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // DDR
    else if (int_id <= 135) { /* do nothing */ } // FPGA, !!!
    else { trigger_type = ALT_INT_TRIGGER_LEVEL; } // everything else
    switch (trigger_type)
    case ALT_INT_TRIGGER_LEVEL:
    alt_clrbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
    break;
    case ALT_INT_TRIGGER_EDGE:
    alt_setbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
    break;
    default:
    "Did you suggest I test the time form the isr signal send to GIC to the interrupt callback function called". Yes in C code only can write piece of code for timer before ISR start and end.
    Tiwari
