The cyclone v soc GIC interrupt priority issues
- 3 years ago
Please check this below API function, you can also directly set the LEVEL or EDGE triggered.
ALT_STATUS_CODE alt_int_dist_trigger_set(ALT_INT_INTERRUPT_t int_id,
ALT_INT_TRIGGER_t trigger_type)
// See GIC 1.0, section 4.3.12.
if ((uint32_t)int_id >= ALT_INT_PROVISION_INT_COUNT)
return ALT_E_BAD_ARG;
else if ((alt_int_flag[int_id] & INT_FLAG_IMPLEMENTED) == 0)
else if (int_id < 16)
if ( (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
|| (trigger_type == ALT_INT_TRIGGER_SOFTWARE))
return ALT_E_SUCCESS;
else
else
uint32_t regoffset = int_id >> 4;
uint32_t regbitshift = ((int_id & 0x0F) * 2) + 1;
if (trigger_type == ALT_INT_TRIGGER_AUTODETECT)
if (int_id <= 32) { trigger_type = ALT_INT_TRIGGER_EDGE; } // PPI
else if (int_id <= 40) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU0_PARITYFAIL
else if (int_id <= 47) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU0_DEFLAGS
else if (int_id <= 56) { trigger_type = ALT_INT_TRIGGER_EDGE; } // CPU1_PARITYFAIL
else if (int_id <= 63) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // CPU1_DEFLAGS
else if (int_id <= 66) { trigger_type = ALT_INT_TRIGGER_EDGE; } // SCU
else if (int_id <= 69) { trigger_type = ALT_INT_TRIGGER_EDGE; } // L2_ECC
else if (int_id <= 70) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // L2 (other)
else if (int_id <= 71) { trigger_type = ALT_INT_TRIGGER_LEVEL; } // DDR
else if (int_id <= 135) { /* do nothing */ } // FPGA, !!!
else { trigger_type = ALT_INT_TRIGGER_LEVEL; } // everything else
switch (trigger_type)
case ALT_INT_TRIGGER_LEVEL:
alt_clrbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
break;
case ALT_INT_TRIGGER_EDGE:
alt_setbits_word(alt_int_base_dist + 0xC00 + regoffset * sizeof(uint32_t), 1 << regbitshift); // icdicfrn
break;
default:
"Did you suggest I test the time form the isr signal send to GIC to the interrupt callback function called". Yes in C code only can write piece of code for timer before ISR start and end.
Tiwari
I think you can calculate time by using the timer before starting the ISR and stopping at the end of ISR.
Also, in below API,
"alt_int_dist_trigger_set(ALT_INT_INTERRUPT_GPIO2, trigger_type);"
trigger_type:
- ALT_INT_TRIGGER_AUTODETECT
- ALT_INT_TRIGGER_EDGE
- ALT_INT_TRIGGER_LEVEL
Tiwari
For SOC_CV_AV, using AUTODETECT will return -1 for FPGA interrupt int register.
Please check the <alt_interrupts.c> line 838 to 851
"I think you can calculate time by using the timer before starting the ISR and stopping at the end of ISR."
Please correct me if Im wrong:
Did you suggest I test the time form the isr signal send to GIC to the interrupt callback function called?
