16 years agoTesting Verilog design with Matlab
Hi!
I have done a design using Quartus II and I need to test it by using Matlab. Is there any way to link Quartus with Matlab?? Thank you. Joan3 Replies
thank you very much!! I will try those things. First I have to install Matlab 7, because I have 6.0.
the Mathworks does offer some solutions for integrating ModelSim into MATLAB/Simulink.
you can also make a test bench which reads and writes text files that you can generate and analyze in MATLAB. - Altera_Forum
I think you can use a "Black box" simulink block from Altera's DSPbuilder to encapsulate your VHDL/verilog code, then make your matlab code communicate with the HDL via simulink.
I did this once with Xilinx tools and worked great. Altera offers similar functionality.
