16 years agotest sram in nios ok,but sram can not be program memory
Hi everyone! I have a test program for sram like as follows: alt_u16 *temp=SRAM_16BIT_512K_BASE; alt_u16 i=0; alt_u16 data[100]; int main(void) { for(i=100;i<200;i++) { *(temp+i)=i; } temp=SRAM_16BIT_512K_BASE; for(i=100;i<200;i++) { data=*(temp+i);
printf("data[%d]==%d\n",i,data); } while(1) {} return 1; } SRAM_16BIT_512K_BASE =0x80000 It is the address about sram in nios-system, The result show me that write sram and read sram is ok. I have also test it in debug module ,with step-in module I can see that memory of sram have been writeen ok. But when I set sram as program memory ,there are something wrong about it. Wrong information is :verified 0x80000 and 0x81f70 failed when I run it! So i wish someone can help me!!:confused:
Just for your information, your code may not actually test your sram. The Nios CPU has a data cache, and with only 100 16-bit accesses, it is probably all kept in the cache.
In order to actually test the SRAM, you would need to either use the alt_remap_uncached() function to define your temp pointer, or use the IORD/WR macros to read/write the memory. - Altera_Forum
Yes,now when my program is little,nios download ok and there is no verify failed infomation ,but the program can not run in it.
Because in the program I use "printf()" function printf a "Hello!"information to ide_console. So do you have some advice to me? - Altera_Forum
Did you connect the instruction bus?
