16 years agotest sram in nios ok,but sram can not be program memory
Hi everyone! I have a test program for sram like as follows: alt_u16 *temp=SRAM_16BIT_512K_BASE; alt_u16 i=0; alt_u16 data[100]; int main(void) { for(i=100;i<200;i++) { *(te...
16 years agoIt's more likely that you have a problem on your board, such as a bad connection, or a bad configuration of the pll or pins, or problems with the pll power supply.
