17 years ago
Tcp_ip, Sopc
hello,
i have a bord STRATIX II EP2S60, i use quartus 2 v7.2.
i would like to use nichestack tcp/ip for nios 2, I don't know if i must use the MicroC/OS for this or i can avoid it (i don't know if i have the choice or no).
thanks.
    Hi, on an other project, I try to use InterNiche Stack in superloop mode and I have the same problem noticed in http://www.alteraforum.com/forum/showpost.php?p=9433&postcount=8 (post# 8) but with a DP83848C PHY.
    --- Quote Start ---
    prepped 0 interfaces, initializing...
    inet startup error: unable to find any working interfaces
    panic: IP
    dtrap - needs breakpoint
    --- Quote End ---
    Do I need to use ETH_OCM_INSTANCE() elsewhere ?
    i use quartus and nios ii ide 9.0sp2 , internichestack in superloop mode, ethernet opencore mac (and dp83848c phy)
    I found the mistake : :D
    I use a crossed cable between PC <-> board and DHCP was enabled.
    simply disable dhcp and it seems to work.
    --- Quote Start ---
    --- Quote End ---
    Hi, how can you make it work. And what do you mean disable DHCP. I tried to make it by set the variable
    *use_dhcp = 0;
    but it didn't work for me. I am still getting the error
    inet startup error: unable to find any working interfaces (using cross cable PC and DE2-70 board)
    I am using the 13.1 version of both NIOS-II EDS and the Quartus-II Programmer. I am also seeing the same problem described in this thread. Ethernet device is not being detected. The version of BSP that I have calls "ALTERA_AVALON_SGDMA_INIT" from "alt_sys_init()" which looks like a ethernet subsystem but I still don't see any ethernet devices.
    Has this issue been resolved by anybody? Can somebody provide me with some pointers?
    -Srinath
