18 years agoTcp_ip, Sopc
hello, i have a bord STRATIX II EP2S60, i use quartus 2 v7.2. i would like to use nichestack tcp/ip for nios 2, I don't know if i must use the MicroC/OS for this or i can avoid it (i don't...
16 years agoHi, on an other project, I try to use InterNiche Stack in superloop mode and I have the same problem noticed in http://www.alteraforum.com/forum/showpost.php?p=9433&postcount=8 (post# 8) but with a DP83848C PHY.
--- Quote Start --- prepped 0 interfaces, initializing... inet startup error: unable to find any working interfaces panic: IP dtrap - needs breakpoint --- Quote End --- Do I need to use ETH_OCM_INSTANCE() elsewhere ? i use quartus and nios ii ide 9.0sp2 , internichestack in superloop mode, ethernet opencore mac (and dp83848c phy)
