16 years agotcl commands in Altera Modelsim
Hi all!
I am using Altera Modelsim, which is tcl-based. I use the GUI. In the console, when I type the command puts "a" I get not output: ModelSim> set a 1 # 1 ModelSim> echo $a # 1 ModelSim> puts $a ModelSim> puts "a" ModelSim> Can anyone explain that? Thx13 Replies
When you start vsim, try to use the "-gui" option, like "vsim -gui"
--- Quote Start --- When you start vsim, try to use the "-gui" option, like "vsim -gui" --- Quote End --- That is indeed the solution for me, thanks. - Altera_Forum
I just tried this under Windows 7 with Quartus 15.0 Modelsim 10.3d. I started a NIOS II IDE shell first, used 'which vsim' to confirm I was going to run the correct version of Modelsim, and then ran 'vsim', without the -gui option. The Modelsim GUI console output was:
The first "Hello!" was printed on the NIOS II IDE shell command-line. Adding the -gui option redirects the output to the GUI console. Thanks for posting your solution, it works great! :) Cheers, DaveModelSim> puts "Hello!" ModelSim> echo "Hello!"# Hello!
