16 years agotcl commands in Altera Modelsim
Hi all! I am using Altera Modelsim, which is tcl-based. I use the GUI. In the console, when I type the command puts "a" I get not output: ModelSim> set a 1 # 1 ModelS...
9 years agoI just tried this under Windows 7 with Quartus 15.0 Modelsim 10.3d. I started a NIOS II IDE shell first, used 'which vsim' to confirm I was going to run the correct version of Modelsim, and then ran 'vsim', without the -gui option. The Modelsim GUI console output was:
ModelSim> puts "Hello!"
ModelSim> echo "Hello!"# Hello!
The first "Hello!" was printed on the NIOS II IDE shell command-line. Adding the -gui option redirects the output to the GUI console. Thanks for posting your solution, it works great! :) Cheers, Dave
