15 years ago
tcl commands in Altera Modelsim
Hi all!
I am using Altera Modelsim, which is tcl-based. I use the GUI.
In the console, when I type the command puts "a" I get not output:
ModelSim> set a 1
# 1
ModelSim> echo $a
# 1
ModelSim> puts $a
ModelSim> puts "a"
ModelSim>
Can anyone explain that?
Thx
    When you start vsim, try to use the "-gui" option, like "vsim -gui"
    --- Quote Start ---
    --- Quote End ---
    That is indeed the solution for me, thanks.
    I just tried this under Windows 7 with Quartus 15.0 Modelsim 10.3d. I started a NIOS II IDE shell first, used 'which vsim' to confirm I was going to run the correct version of Modelsim, and then ran 'vsim', without the -gui option. The Modelsim GUI console output was:
    ModelSim> puts "Hello!"
    ModelSim> echo "Hello!"#  Hello!
    The first "Hello!" was printed on the NIOS II IDE shell command-line.
    Adding the -gui option redirects the output to the GUI console.
    Thanks for posting your solution, it works great! :)
    Cheers,
    Dave
