SYiwe
7 months agoSystem PLL of Agliex5 PCIE example design cannot be locked after configuration
Hi all, The device is Agilex 5 E series FPGA, development kit is plugged in main board via a x16 card edge. Both System PLL reference clock and PCIE AXI Stream Hard IP reference clock are driven fr...
SYiwe
7 months agoHi Frank,
Thank you for your reply.
- How Can I confirm whether system PLL support spread spectrum modulated reference clock or not? I read PCIE IP and Native PHY user guide but no relative information found.
- Do you mean that I can try to disable PCIE card edge reference clock spread spectrum modulated function in BIOS when the main board linux system start up?
I will be appreciated if you can show me more suggestions, regards.
FvM
7 months agoHi SYiwe,
system PLL has usually low bandwidth setting while PCIe PLL is set for wide bandwidth. My understanding is that wide bandwidth setting is necessary to support spread spectrum reference clock. You may try to change system PLL setting also to wide bandwidth and check if it will lock then.
Frank
