11 years ago
system console, external memory, multiple masters
Hi guys
Im fairly new here.
Im working with a cyclone V GX board and have used qsys to add a memory controller in my nios code to control some lpddr memory on the eval board.
Im using system console to write some values to the memory, but i notice that system console finds 2 masters: the memory and the nios.
I can use system console to write to the memory using the valid address values that qsys assigned, but i need to use the master assigned to the memory (not nios).
My problem is that i need nios to access what i write to external memory. In my nios code, i try read that same valid address that points to my lpddr memory, but its not the same as what i wrote with system console.
I was under the impression that the "avalon memory master" would take care of letting nios see that memory.
Am i missing something in my qsys system? Im trying to learn everything at once :)
Can you guys help me understand what i need to do?
I can post code/screenshots if needed
thanks!!!!
