18 years agoSynthesis with input pin mode constrain
Hi, I am having an input to my module, which decides the mode of operation of the system. But, the user using my IP knows that, in what mode it is going to operate so, he can permanently ti...
18 years ago --- Quote Start --- Hi freak, is the input really necessary, means is there a request that you can change the operation mode running in the application ? --- Quote End --- In verilog you can use `ifdef for controlling the synthesis. I have made a small example: module if_def_test ( clk , in , out); input clk; input in; output out; reg reg_int1, reg_int2, reg_int3; `ifdef synth assign out = reg_int1; `else assign out = reg_int3; `endif always @(posedge clk) begin reg_int1 <= in; reg_int2 <= in; reg_int3 <= reg_int2; end endmodule In the example the length of the register chain is controlled by setting the macro "synth". "synth" is name of the macro, of coarse you can choose a different one. You can set the macro to "1": Assignment -> Settings -> Analysis & Synthesis Settings -> HDL Verilog Input -> Verilog HDL Macro Name : synth Value : 1 Doing so only reg_int1 will be implemented. Try it and have fun.
