16 years ago
synthesis of VHDL module
is it possible to synthesis of VHDL module if there is integer variables in the VHDL module ?
is it possible this module to be synthesized ?
library ieee;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all;
entity clock is
port  (
clk, reset: inout std_logic;
fast_clk : inout std_logic ;
d: in std_logic_vector(5 downto 0) ;
Q :out std_logic_vector(16 downto 0);
enable : inout std_logic ;
sec_bin             : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ;
min_bin             : OUT STD_LOGIC_VECTOR(5 DOWNTO 0)
end clock;
architecture arch of clock is
beginentity clock is
port  (
end clock;
begin
process   (clk, reset )
  VARIABLE sec : INTEGER  ;
  VARIABLE min : INTEGER  ;
begin
  if (clk'event and clk = '1') then
  if (enable = '1') then
    if (reset = '1') then sec  := 0 ; min := 0; end if;
       if (sec < 60) then sec := sec +1; else sec := 0; if ( min < 60) then min := min +1; else min := 0 ;  end if; end if ;
  sec_bin<=CONV_STD_LOGIC_VECTOR(sec,6) ;
  min_bin<=CONV_STD_LOGIC_VECTOR(min,6) ;
    end if ;
  end if;
end process;
end arch;
    no, keep the sec_bin and min_bin inside the clock assignments.
    The best thing for you to do is just test it and simulate it until it works
    so the code must look like this
    library ieee;
    entity clock is
    port  (
    end clock;
    begin
    begin
        end if ;
      end if;
    end process;
    end arch ;
    PS. why have you set clk, fast_clk, reset and enable ports to be inout rather than just in?
    Theres no problem with that, but I feer you're not quite going to get what you expect.
    Variables update immediatly, so sec_bin and min_bin are going to be the output of the adder direct rather than the output of the register holidng the values of sec and min.
    To prevent this, move sec_bin and min_bin assignments to be before the variable assignments.
