16 years agoSum of bit vectors
Can someone tell me which is the most efficient way to sum 40 signanls ?Each of them is 8 bit long.Thanks in advance
16 years agoOk, go to quartus tools menu then megawizard plug-in manager and choose
parallel_add from the arithmetic group. Then set your parameters e.g. bit width, number of inputs, size of output, pipeline stages. Thats all. then you get the adder component , just connect it in your project. If the number of inputs allowed in your case is < 40 then you can use two instants...
