Stratix10 PCIe clock structure issue
Hi allen18,
Referring to the Stratix 10 Pin Connection Guidelines (pg. 9), the on-board oscillator is not used for PCIe, it is used for device configuration and transceiver calibration.
Stratix® 10 Device Family Pin Connection Guidelines: https://www.intel.com/content/www/us/en/docs/programmable/683028/current/device-family-pin-connection-guidelines.html
Ven
Hi ventt,
My reference clock comes from a crystal oscillator, which has a frequency of 100MHz , not the OSC-IN pin, OSC-IN connected to another 125MHz crystal oscillator.
As shown in the figure, AV33,AV34,The common clock, connected to PC board via oculink. AT33, AT34 come from a crystal oscillator on FPGA board. AV33,AV34, This set of clocks is working normally. If I connect to AT33, AT34, Will not work properly and print errors.
Please help investigating why the latter set of clocks is not working properly.
