STRATIX10 GX device : 1SG280HNF43 with JTAG ID CODE : 0xC32250DD CLK PINS don't work.
Thank you for responding. We purchased the Stratix10 GX development kit and we were assuming the part number will be
https://bsdl.info/details.htm?sid=10b82bfd8620771788ca59b002289d77
Is this correct?
We are generating the waveform using Synopsys in house tools and don't see valid sample data. for the clocks mentioned above.
Hi there
I am not the expert in JTAG Programming. I realize you have another thread discussing on it, perhaps you can continue to get the confirmation in the thread:
We need to make sure the FPGA is in user mode, before we looking for clock sample data. And also at which node you get the sample data?
Eng Wei
- app_engineer5 years ago
How do I ensure the board is in user mode. Is there a switch I need to toggle physically on the board. I'm capturing sample using our in house synopsys tools. But the sample data on hw shows X's which I presume is because of the sampling clock not getting to the bus.- EngWei_O_Intel5 years ago
Hi there
Sorry for late response due to my extended holidays. We can check the INIT_DONE signal to make sure the configuration is done and enter user mode.
We can refer to the flow is below doc:
thanks.
Eng Wei
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
