12 years agoStratix IV smd oven reflow cycles allowed
Hi all member,
I have a simple request, how many reflow cycles is allowed for Stratx IV? Very thanks in advance for your kindly cooperation. Best Regards, Fabrizio3 Replies
I'm not a process expert but I strongly suspect Altera will only recommend/support a single reflow cycle for their parts.
Altera do have the following application note on the reflow process: http://www.altera.com/literature/an/an353.pdf (http://www.altera.com/literature/an/an353.pdf) This discusses 'BGA Rework' but assumes you're replacing a defective device. It also clearly identifies Altera's process recommendations and identifies the time any device should spend within 5 degreesC of peak - 30 seconds for Pb-Free. You may argue that providing 2 or more reflows don't add up to more than this period you're fine. However, Altera specify this time as part of a single reflow process. So, unless your process allows this sort of time at peak I'd suggest you're compromising it. - Altera_Forum
I'm not sure what you are asking about. You may use two reflow cycles of a board in double side assembly, but FPGAs would be usually placed in the second cycle. In rework, you don't reflow solder a complete board.
Most FPGAs are moisture sensitive devices and must be baked before soldering when exposed longer than 2 to 7 days (depending on the sensitivity level) to ambient air. - Altera_Forum
Devices can be removed, re-balled and refitted without reflowing the entire board, just applying heat to the particular part. This process cycle would mean a package would be subjected to 3 reflow cycles.
I suspect this is not something Altera recommend or support. They are likely to recommend replacing suspect/damaged parts with new ones.
