16 years agoStratix IV GX transceivers: 32-bit word alignment in basic mode?
Hi. I'm working on the transceivers of a Stratix IV GX series FPGA. The handbook covers word alignment quite well for smaller data widths (e.g. 8, 16), but is vague when it comes to word align...
14 years agoHi,
I'm using the following alignment pattern: 0x0000BC1C BC and 1C are both 8/10b control bytes. In the megafunction, I'm using the following settings: -Basic mode -32 bits -8/10 endoding (obviously) -Manual word alignment mode (assert the rx_enapatternalign when you know the RX is receiving the alignment pattern) -Word alignment pattern is 20 bits -Word alignment pattern: 01011111000010111100 (= 0x5F0BC) Note: The alignment pattern is entered in the megafunction in its 10/8 encoded form, so 0xBC1C becomes 0x5F0BC. -In addition, I use a byte ordering block (based on the syncstatus signal of the word aligner) that triggers on the last 1C of 0xBC1C. As this 1C will be encoded as a control word, I entered 000000000 100011100 as byte ordering pattern where 00011100 is 0x1C and the preceding b'1 is the control_detect flag bit. So, to summarize, I put 0x0000BC1C on the 32-bit TX user data bus where the 0xBC1C portion is 10/8 encoded as control bytes (assert tx_ctrlenable to do this) and transmitted as 0x5F0BC. The RX side word aligns to this (when rx_enapatternalign is asserted) pattern and performs byte ordering using the last 0x1C. The I put my user data on the parallel TX bus and it shows up correctly on the RX side. p.s. - I assume the transceiver is initialized properly; that the analog and digital resets are released in the correct order and based on the pll_locked and rx_freqlocked outputs etc., as described in the handbook)
