17 years agoStratix III EP3SL340c3 Diffrential IO data rate
Hi I have been working on DE3 board with the above mentioned FPGA for some months now. I am trying to deserialize 8 LVDS channels from an ADC. each channel is 12 bits and ADC can work upto 50 Mega...
17 years agoHey FvM,
The problems with HSTC is that these four connectors have a combined 8 Dedicated clock pins (on reciever side) whereas i need 12x2= 24 (12 adc and each having 2 clocks). lets assume i get past this issue using IO pins, i will need a 16.66% duty cycle, 25MHz signal for "tx_enable" whereas one from ADC is 50% duty cycle and 50 MHz. I am still not convinced if i can use a SERDES/ALTLVDS megafunction.
