18 years agoStratix II PLL and crossing clock domains
Hi, I want to transfer data between two clock domains(12 MHz to 20 MHz). I am using a Stratix II FPGA PLL to generate both clocks from a 100 MHz clock. I need that the first rising...
18 years agoAs I said. By defining a 4 MHz clock in the same PLL. Each edge of it is aligned with both other clocks. All PLL clocks (with zero phase shift) are initially aligned at a PLL reset.
