Stratix II EP2S15F484C5 and EPC4 pof file generation
Dear all,
I am working on a project using a EP2S15F484C5 and EPC4 device. The quartus version is 10 which is the latest that can be used.
When converting the .sof file to .pof file using the "Convert Programming File" command one is has to create two pages for the sof files to reside in or else the error "Programmer Object file for local update must use both Page 0 and Page 1" crops up.
Is there a way to use a single page only. We only need to program 1 FPGA with a single version at a time.
Thanks for the help,
Joseph
- FakhrulA_altera
Please be advised that due to the absence of a response from you regarding the previous notification we provided, we will be transitioning this thread to community support. If you have any new questions or concerns, we kindly suggest opening a new thread to receive assistance from Intel experts. However, if you do not have any further inquiries, the community users will be available to assist you on this thread. Thank you for your understanding.
- FakhrulA_altera
Hi jozamm,
A Programmer Object File (.pof) for Local Update is a Programmer Object File that consists of a local update enabled Programmer Object File and additional local update enabled SRAM Object Files, and is used to program configuration devices in local update configuration mode. You create a local update enabled Programmer Object File by adding local update enabled SRAM Object Files to a Programmer Object File in the Convert Programming Files dialog box. Refer here for details: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_pof.htm
and also here: https://www.terasic.com.tw/wiki/Chapter_4_Setting_for_change_.sof_file_to_.pof_file
Fakhrul
