jozamm
2 years agoStratix II EP2S15F484C5 and EPC4 pof file generation
Dear all, I am working on a project using a EP2S15F484C5 and EPC4 device. The quartus version is 10 which is the latest that can be used. When converting the .sof file to .pof file using the "Conv...
FakhrulA_altera
2 years agoHi jozamm,
A Programmer Object File (.pof) for Local Update is a Programmer Object File that consists of a local update enabled Programmer Object File and additional local update enabled SRAM Object Files, and is used to program configuration devices in local update configuration mode. You create a local update enabled Programmer Object File by adding local update enabled SRAM Object Files to a Programmer Object File in the Convert Programming Files dialog box. Refer here for details: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_pof.htm
and also here: https://www.terasic.com.tw/wiki/Chapter_4_Setting_for_change_.sof_file_to_.pof_file
Fakhrul
