16 years agoStratix II Configuration Problem
Hi, We are having some issues configuring a stratix II FPGA. From quartus we can successfully program the flash from Quartus but the FPGA does not always configure correctly when power is applied....
16 years agoI'm seeing the same problem with a Cyclone II. Part doesn't configure at power up. Everything checks out and works with the USB Blaster.Sits there retrying continuously. When I tap the DONE line with a scope probe, part springs to life.
Have probed lines; the PCB layout is fine, and the tracks are about 2" long. Good signal integrity at the Cyclone II. Have tried decreasing pullup value on DONE, adding a small capacitor, etc.... -------------revised post ------ FIXED IT-------------- Was originally using EPCS1 with compressed bitstream. Changed to using EPCS4 and uncompressed stream. Worked first time. Was using Quartus 9.1 build 222, EP2C8Q208C8
