16 years agoStratix II Configuration Problem
Hi, We are having some issues configuring a stratix II FPGA. From quartus we can successfully program the flash from Quartus but the FPGA does not always configure correctly when power is applied....
16 years agoMy apologies for not posting back on this issue earlier. A few other things came up and I was unable to spend time with this particular issue. We have some other boards which do not exhibit the same problem. So hopefully I will be able to get back to this issue at some stage in the near future and try the suggestions as it does seem like a noise issue.
I´ll post back when I have more information or a solution as it may be of use to someone else at some stage in the future. Regards
