16 years agoStratix II Configuration Problem
Hi, We are having some issues configuring a stratix II FPGA. From quartus we can successfully program the flash from Quartus but the FPGA does not always configure correctly when power is applied....
16 years agoWell the fact that probing CONF_DONE fixes it is more than odd. We know that CONF_DONE must go high for the device to initialize. Maybe what's happening is noise on the CONF_DONE line is actually causing it to not initialize because you've got the traces running all over.
I have two different experiments to try. I would try number 1 first. 1 - Can you add a capacitor between CONF_DONE and ground? Doesn't have to be too big. maybe 100pF. Though I don't think a larger value could hurt. You could probably actually lay it on top of R418. This would bypass to 3.3 instead of GND but I think either way will work. Try both if one doesn't have any effect. 2 - Try changing change R148 to 1K. Jake
