16 years agoStratix II Configuration Problem
Hi, We are having some issues configuring a stratix II FPGA. From quartus we can successfully program the flash from Quartus but the FPGA does not always configure correctly when power is applied....
16 years agoYou're schematic isn't attached. Can you attach it?
Clarifications: 1 - So you say that the FPGA seems to always successfully configure when you have a scope probe on the CONF_DONE pin? 2 - Not seeing the schematic, it sounds like your traces are T'd going between the three devices (EPCS64, Stratix II, & Cyclone III). How does the signal integrity look on the Active Serial configuration pins? 3 - Are you using fast active serial or regular active serial? If fast, are you able to try slow? 4 - Have you probed the nConfig pin to see if something is happening there? Is the nConfig pin properly pulled high? 5 - Do you have sufficient grounding to the FPGA? Can you list any differences you can think of between this design and the other board that works properly? Jake
