16 years agoStratix 2 Gx
I want to implement 4 channel transceiver of data/ The problem is that I need that all the four channels would be aligned, I mean the data in all four channel will have a constant phase (but every ti...
16 years agoIf a (CMU) PLL output is shared amongst the RXs within a quad, that means to me the 4 RX Buffers will sample the incoming serial streams at the same instant but does it make sure the 4 deserializer outputs are aligned ?...
If RXs are bonded, a common refclock feeds: 1) the PFD of the RX CDRs (depending on LTR/LTD mode ? =>TB checked) 2) the RX phase compensation FIFO wrclk but each RX provides its own serial and parallel recovered clock. I don't see any guarantee for each of the 4 deserializers will be clocked with the same parallel (low-speed) clock phase. A bit misalignment between incoming serial streams would rather focus my attention on the PCS word aligner. Are you using an alignment pattern ?
