16 years agoStratix 2 Gx
I want to implement 4 channel transceiver of data/ The problem is that I need that all the four channels would be aligned, I mean the data in all four channel will have a constant phase (but every ti...
16 years agoYes I connected the same reset to all the transceiver. You think that the FIFO block is the reason? I can turn it off. But still if the FIFO is to blame, why I get phase that are not a full cycle (of the serial data- in my case 4.4 gbs) delay-sometimes I get just part of it (half for example)?
