OrF's avatar
OrF
3 years ago
Stratix 10M DIB Module
Hi
I'm using the DIB to inter connect between the 2 dies of the Stratix 10
I'm using it in BYPASS (therefore I need to define the constraints) mode and one of the IO is transferring clock from one side to another - source synchronous.
I generated DIB Module from the IP catalog (dib_rx_altera_dib_1930_u7lqq6i)
at the synthesis / fitter stage I would like to assign the constraints to the IO
the question is to where should I assign / define the Clock in the constraints , and the input delay ?
to DIE1_dib_pad_2_22_2[18] or to OUT[18] (in the case of the Clock) , and similar to the input delay ?
if I will assign Input Side DIE1_dib_pad_2_22_2[18] - will quartos/ timing analyzer will understand that OUT[18] is a clock (and take into account the routing delay) ?
or the dib_0 module is Blackbox for the timing analyzer and I should define the clock and IO input delays on the OUT[18] ?
my understanding that the input from the EMIB inserted to the Die1 via DIE1_dib_pad_2_22_2[18] , dib_0 module does nothing in bypass mode (just routing) , and the OUT[18] is the continuation of the wire .
thanks
Or.
  • Hi,
    I cannot seem to get engineering to confirm the values, but the normal practice is by adjustment.
    You can start with the values they put for the example design and fine tune it after compilation.
    Below are the values used:
    • max C=2.65
    • min C=-2.65
    • max A + max B = 8.25
    • min A + min B = 3
    • max D + max E = 4.75
    • min D + min E = -1.64
    Nurina
  • Nurina's avatar
    Nurina
    Hello Or,
    What I mean by delay matched clock is that the clock hitting the clock pin of each die is matched. Best way to do that is to have a clock gen on your board with two matched outputs and route those signals to each die with matched trace lengths. That ensures that each FPGA has a clock coming in that's matched.
    In this case you wouldn't need the DIB IP at all.
    It is possible to send a clock over from one die to another using DIB IP, but due to high clock uncertainty, it will be very difficult to ensure the proper timing constraints and addressing any potential CDC. There is a high chance of hardware failure which is why I'm suggesting against sending a clock over through DIB IP.
    To generate the example design, go to Project>Upgrade IP Components and double click on the DIB IP and Quartus will open IP Parameter Editor. At the toolbar go to Generate>Generate Example Design. Once generating the example design, you can run a compilation and take a look at the SDC file in the example design. The example design will use 50MHz clock by default.
    Nurina
    • OrF's avatar
      OrF
      Hi
      regarding your comment : "In this case you wouldn't need the DIB IP at all."
      - if I get you right , you mean that I don't need DIB IP for sending clock from die to die ?
      , but I do need DIB IP for transferring data from Die to Die (I dont see other way to transfer data )
      Or.
  • Nurina's avatar
    Nurina
    • max C=2.65
    • min C=-2.65
    • min A + min B = 3
    Nurina
  • Nurina's avatar
    Nurina
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
    Nurina
