Volodymir
4 years agoStratix 10 PCI Express Avalon®-MM DMA Reference Design. Interrupt generation.
Hello ! Working with a Stratix 10 board. Per AN 829: PCI Express* Avalon®-MM DMA Reference Design built the design and uploaded it to the board. I work with Windows. I successfully run DMA Read, DM...
Volodymir
4 years agoHello ! thanks for your reply !
Your question :
- Can I know which description and which document that you are referring at ?
This is UG - 20033 (2019.07.18) Intel Stratix10 Avalon - MM Interface for PCI Express Solutions User Guide.
7.2.1. PCI Express Avalon-MM Bridge Register Address Map.
- Can you specific which BAR that you need to translate ?
as shown in the Qsys structure (picture above), from the BAR 0 register I get access to the DMA mechanism. bar4 provides access to the internal memory. at the moment I don’t know how to access the Avalon-MM to PCIe Interrupt Enable Register via CRA
thanks for the answer
