yashael's avatar
yashael
4 years ago
Stratix 10 PAC HSSI example
I'm trying to understand how to use the hssi interface in stratix 10 PAC. I had some problem on rx_data_valid (PCS Direct on serial loopback)
But unable to reproduce the issue, so i'm creating a new issue to ask how to use it properly.
I tried modifying the hssi_prbs example code, to be more precise i'm trying to change the pattern_gen.v and pattern_ver_pipelined.v into just a simple counter.
However, after changing both of them, the rx_ready is always fluctuating, and never stable at 0xff.
So, i'm at loss on how to actually use this hssi interface. I tried looking into the transceiver user guide but still don't understand how to use it. Can someone please advise me how to use the interface correctly?
here are the modifications to pattern_gen.v and pattern_ver_pipelined.v
// pattern_gen.v
`timescale 1ps/1ps
module pattern_gen #(
        parameter MAX           = 'hffff,       //width
        parameter width         = 16,       //width
        parameter low_freq_len  = 8,        // (width/(low_freq_len*2)) must be a whole number
        parameter pattern       = "prbs7",   // prbs7, prbs9, prbs15, prbs23, prbs31
        parameter prbs_initial_value = 97
        input  wire             clk,
        input  wire             reset,
        input  wire             enable,
        output wire [width-1:0] data_out,
        output wire             valid
    reg [width-1:0] counter;
    always @(posedge clk) begin
        if (reset)
            counter <= 'd0;
        else if (enable)
            counter <= (counter == MAX) ? counter : counter + 'd1;
        else
            counter <= counter;
    end
    assign valid    = enable & ~(counter == MAX);
    assign data_out = valid ? counter : 'h0;
endmodule
// pattern_ver_pipelined.v
`timescale 1ps/1ps
module pattern_ver_pipelined #(
        parameter width         = 16,     // width
        input                       clk,
        input                       reset,
        input                       enable,
        input [width-1:0]           data_in,
        output                      data_locked,
        output reg                  error
    reg [width-1:0] ref_value;
        if (reset)
            ref_value     <= 'd0;
        else if (enable)
            ref_value     <= (ref_value == MAX) ? ref_value : ref_value + 'd1;
        else
            ref_value     <= ref_value;
    end
    reg [width-1:0] err_count;
        if (reset)
            err_count     <= 'd0;
        else if (enable && (ref_value == data_in))
            err_count     <= err_count + 'd1;
        else
            err_count     <= err_count;
    end
        if (reset)
            error   <= 'd0;
        else if (data_locked)
            error   <= err_count > 'd0;
        else
            error   <= error;
    end
    assign data_locked = ref_value == MAX;
endmodule
  • JohnT_Altera's avatar
    JohnT_Altera
    There is no simulation for the HSSI IP. I would recommend that you try to look at the resync block which help to syncronize the data between the TX and RX before you are able to expect the correct data.
  • yashael's avatar
    yashael
    I'm extracting simulation files from Stratix 10 Native PHY IP, then simulate it in modelsim.
    In the simulation, i tried using resync block for the receiver data, and some data is missing.
  • yashael's avatar
    yashael
    Hi, I tried implementing a word aligner by sending a pattern (0xF0000000). because of the bitslip, the RX then will receive a different value (e.g 0x003c0000).
    But then it turns out that the bitslip is not constant throughout the transfer.
    To prove that there's are bitslips happening, I took a screenshot of the receiving part. This time, the prbs_din is sync using resync.
    The expected sequence of the 5 first word are: 0x55555555, 0x5fffffff, 0x2a000000, 0x17a00000, 0x0aaa0000.
    But if you see the screenshot, you can see that the words are getting mixed, for example
    0xfd555555 is parts of the first and second correct sequence. thus showing a bit slip.
    Although the prbs check is shows no error, the data itself is not correct.
    To reproduce this error, you can compile hssi_prbs example with the attached prbs_top.v and hssi.stp within src.zip.
    Is there any pattern to this bitslip? How do I fix this bitslips?
    I really need this to work, my goal is just simply moving data from 1 fpga to another.
    Please advise a way to correct the received data.
