yashael
4 years agoStratix 10 PAC HSSI example
I'm trying to understand how to use the hssi interface in stratix 10 PAC. I had some problem on rx_data_valid (PCS Direct on serial loopback) But unable to reproduce the issue, so i'm creating a ...
JohnT_Altera
4 years agoHi,
There is no simulation for the HSSI IP. I would recommend that you try to look at the resync block which help to syncronize the data between the TX and RX before you are able to expect the correct data.
