7 years agoStrange PLL Clock causing me failing paths in cyc V design
Dear all,
TimeQuest is warning me of a failing path in my Altera Cyclone V FPGA design. It says failing path with:Slack______From Node ____________________________________ ____to Node __________Launch Clock ____________________________________________________________________________Latch clock____Relationship __Clock Skew ___Data Delay
-9.115 ____ io_control:io_control_inst1|data_out _______ dq _______ pll_inst_100|pll_100_inst|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk ______ clk_100____ 10.000 ____ -10.144______2.901
I wonder what is the problem here and what clock divclk is? The entity io_control flops the data from inside the design and tristating it to dq. dq is an Input / Output Port at the top level design. IO_control has clock input clk_100. clk_100 is routed globally through the design with an ALTCLKCTRL. The clk_100 is feed to external hardware via ALTDDIO which is consuming dq. Here is the code of IO_control: flopping_data_out_proc : process(CLK, RESET)begin
if (RESET = '0') then
data_out <= (others => '0');
elsif (rising_edge(CLK)) then
data_out <= Fin_DATA_ram; -- comes from inside FPGA Design
end if;
end process flopping_data_out_proc;
mux_data_out_proc : process(slrd_en, data_out)
begin
if (slrd_en = '0') then
DATA <= data_out; -- DATA is output of IO Control and wired to DQ
else
DATA <= (others => 'Z');
end if;
end process; Can somebody enlighten me if this is a critical issue? I set all needed timing constraints but wonder if I had to add a multicycle path or set false path between these clocks? It is noticeable that the fitter puts out a warning during fitting: Warning (332049): Ignored create_clock at SDC1.sdc(2): Incorrect assignment for clock. Source node: CLOCK_50_B5B already has a clock(s) assigned to it. Use the -add option to assign multiple clocks to this node. Clock was not created or updated.
Info (332050): create_clock -name CLK1 -period 20.0 This is also the clock which feed the pll (clk_100) as reference clock. Can you help me clarifying this issue? I added the archive file in the attachments. Thank you for any help.
