17 years ago
State Machine- State doesn't set logic as expected
The folowing code is designed to convert a 24 bit value in to 4x 6 bit values to transmit over a 6 conductor cable. At each state I define what my output clock should be by assinging a logic level to GeneratedClk. For some reason the output I get doesn't match what I expect. The clock only makes one cycle low and then back to high. I am sure there must be some easy explanation of how I don't understand variables vs. signals or something, but I would appreciate some advice.
entity DataTransmitter is
port (
ClkEnablePort : buffer std_logic;
DataRateClk : in std_logic;
SendData : in std_logic;
DataOutClk : out std_logic;
BusIn : in std_logic_vector(23 downto 0);
BusOut : buffer std_logic_vector(5 downto 0);
SendComplete : buffer std_logic;
Reset : in std_logic
end DataTransmitter;
architecture behavior of DataTransmitter is
type state is ( WaitingForData, Triggered,
SendBits0, LatchBits0, SendBits1, LatchBits1,
SendBits2, LatchBits2, SendBits3, LatchBits3,
SendFinish );
signal pr_state, nx_state : state;
signal GeneratedClk : std_logic;
signal Hold0 : std_logic_vector(5 downto 0); --Least Significant Bits
signal Hold1 : std_logic_vector(5 downto 0);
signal Hold2 : std_logic_vector(5 downto 0);
signal Hold3 : std_logic_vector(5 downto 0);
begin
---------- Advance States ----------
process( Reset, SendData, DataRateClk )
begin
if( Reset = '1') then
pr_state <= WaitingForData;
elsif ( SendData = '1' and pr_state = WaitingForData ) then
pr_state <= Triggered;
Hold0 <= BusIn(5 downto 0);
Hold1 <= BusIn(11 downto 6);
Hold2 <= BusIn(17 downto 12);
Hold3 <= BusIn(23 downto 18);
elsif ( rising_edge(DataRateClk) ) then
pr_state <= nx_state;
end if;
end process;
---------- Create Results for State Change ----------
process( pr_state )
variable SendThisData : std_logic_vector(5 downto 0);
variable GeneratedClk : std_logic;
begin
case pr_state is
when WaitingForData =>
nx_state <= WaitingForData;
GeneratedClk := '1';
SendComplete <= '0';
SendThisData := "000000";
when Triggered =>
nx_state <= SendBits0;
when SendBits0 =>
nx_state <= LatchBits0;
GeneratedClk := '0';
SendThisData := Hold0;
when LatchBits0 =>
nx_state <= SendBits1;
when SendBits1 =>
nx_state <= LatchBits1;
SendThisData := Hold1;
when LatchBits1 =>
nx_state <= SendBits2;
when SendBits2 =>
nx_state <= LatchBits2;
SendThisData := Hold2;
when LatchBits2 =>
nx_state <= SendBits3;
when SendBits3 =>
nx_state <= LatchBits3;
SendThisData := Hold3;
when LatchBits3 =>
nx_state <= SendFinish;
when SendFinish =>
SendComplete <= '1';
when others =>
end case;
DataOutClk <= GeneratedClk;
BusOut <= SendThisData;
end process;
    Thanks for the tips.
    The state machine I had created was designed to latch-out the data on the SendBit(0-3) states and then send a rising edge (DataOutClk) on the LatchBits(0-3) states for the receiver to use to latch the data into the receiver. Unfortunately for some reason the DataOutClk doesn't toggle at every state as I would expect. It seems to skip the middle states. I believe that it enters the states but just doesn't toggle the DataOutClk by setting the GeneratedClk each time.
    Do not use buffer(obsolete).Your state transition is tied up to elsif...
    If you just want to serialise 24 bits into time muxed 6 bits then there might be easier ways of doing what you want e.g.
    signal count: integer range 0 to 3;
    process(reset,clk)
    begin
    if reset = '1' then
       count <= 0;
       input_en <= '0';
       BusOut <= (others => '0');
     elsif rising_edge(clk) then
       count <= count + 1;
       case count is
          when 0 => BusOut <= BusIn(17 downto 12); input_en <= '1';
          when 1 => BusOut<= BusIn(23 downto 18); input_en <= '0';
          when 2 => BusOut <= BusIn(5 downto 0); input_en <= '0';
          when 3 => BusOut <= BusIn(11 downto 6); input_en <= '0';
       end case;
    end process;
    the input_en pulse is to control the input rate(= input clk/4). It needs some care to synchronise the data request to the front module. I have assumed the request is raised at count 0, becomes high at count 1 and data is available soon at count 2. Such design is called pull data flow(not push)
