17 years agoState Machine- State doesn't set logic as expected
The folowing code is designed to convert a 24 bit value in to 4x 6 bit values to transmit over a 6 conductor cable. At each state I define what my output clock should be by assinging a logic level t...
17 years agoThanks for the tips.
The state machine I had created was designed to latch-out the data on the SendBit(0-3) states and then send a rising edge (DataOutClk) on the LatchBits(0-3) states for the receiver to use to latch the data into the receiver. Unfortunately for some reason the DataOutClk doesn't toggle at every state as I would expect. It seems to skip the middle states. I believe that it enters the states but just doesn't toggle the DataOutClk by setting the GeneratedClk each time.
