Sombrero's avatar
Sombrero
7 years ago
Starting Modelsim from Quartus with RTL Simulation on Ubunutu 18.04
Good day everyone,
I am working on the latest version of Ubuntu OS (18.04) and I would like to simulate my FPGA designs with Modelsim via the RTL Simulation of the Quartus Prime V18.1 Lite Version. As soon as I want to start a design simulation from Quartus I get the following error messages:
Error in startup script:
Initialization problem, exiting.
while executing
"Transcript::action_log "PROPREAD \"$key\" \"$value\"""
(procedure "VsimProperties::Init" line 59)
invoked from within
"VsimProperties::Init $MTIKeypath"
(procedure "PropertiesInit" line 18)
invoked from within
"PropertiesInit"
invoked from within
"ncFyP12 -+"
(file "/mtitcl/vsim/vsim" line 1)
** Fatal: Read failure in vlm process (0,0)
I can start both software packages (Quartus, Modelsim) separately from the terminal however starting Modelsim from Quartus doesn't seem to work.
Quartus seems to launch to Modelsim simulation software from the /modelsim_ase/linuxaloem/ directory since I get the same errors when I try to start Modelsim via terminal typing ./vsim at that specific directory... launching Modelsim with ./vsim in /modelsim_ase/bin works, however running ./vsim in /modelsim/linuxaloem/ doesn't. I've searched for hours and got all libpng libraries fixed, went through all helpfull tutorials to get both programs to launch properly but this last problem seems to crack me.
  • I'm not sure if this will solve your problem, but make sure you have the correct location setup in the EDA Tool Options. To change this setting go to Tools > Options, then under 'General' select 'EDA Tool Options' and make sure the path for ModelSim is set to /modelsim_ae/bin instead of /modelsim_ae/linuxaloem.
  • KennyT_altera's avatar
    KennyT_altera
    This issue had been awhile, I would suggest you open a new thread for it.
  • HMeye6's avatar
    HMeye6
    I have the same problem and Bosenraum's proposed solution did not to the trick for me :(
    Any other ideas?
  • Bosenraum's avatar
    Bosenraum
    • Sombrero's avatar
      Sombrero
      Thank you for your reply, Bosenraum! I am giong to test your suggestion soon. I will tell you if I was seccussfull.
