Sombrero
7 years agoStarting Modelsim from Quartus with RTL Simulation on Ubunutu 18.04
Good day everyone, I am working on the latest version of Ubuntu OS (18.04) and I would like to simulate my FPGA designs with Modelsim via the RTL Simulation of the Quartus Prime V18.1 Lite Version....
- 7 years ago
I'm not sure if this will solve your problem, but make sure you have the correct location setup in the EDA Tool Options. To change this setting go to Tools > Options, then under 'General' select 'EDA Tool Options' and make sure the path for ModelSim is set to /modelsim_ae/bin instead of /modelsim_ae/linuxaloem.
Bosenraum
7 years agoI'm not sure if this will solve your problem, but make sure you have the correct location setup in the EDA Tool Options. To change this setting go to Tools > Options, then under 'General' select 'EDA Tool Options' and make sure the path for ModelSim is set to /modelsim_ae/bin instead of /modelsim_ae/linuxaloem.
- Sombrero7 years ago
Thank you for your reply, Bosenraum! I am giong to test your suggestion soon. I will tell you if I was seccussfull.
